The FDT100 Series of water flowmeters uses transit-time ultrasonic technology. The signal is transmitted and received alternately between two flow sensors. Time-of-flight determines flow rate. The battery-powered transmitter comes with either an integrally mounted display or a remote-mount version. Applications include commercial and consumable water measurement.
The FDT100 Series of water flowmeters uses transit-time ultrasonic technology. The signal is transmitted and received alternately between two flow sensors. Time-of-flight determines flow rate. The battery-powered transmitter comes with either an integrally mounted display or a remote-mount version. Applications include commercial and consumable water measurement. With no moving parts, system pressure loss is minimal and filtration is not required. Display flow rate or total at the push of a button.
Omega Engineering, Inc. , www.omega.com
