UR 2000 electric element steam humidifiers use a removable/cleanable stainless steel steam-generating cylinder. The cylinder permits mounting above false ceilings and other difficult areas where pan-coil type units generally can't be used.
UR 2000 electric element steam humidifiers use a removable/cleanable stainless steel steam-generating cylinder. The cylinder permits mounting above false ceilings and other difficult areas where pan-coil type units generally can’t be used. The heating elements are Teflon-coated and can operate dry without burning out. Integral temperature sensors detect mineral buildup and alert the user when cleaning is needed.
DGH Systems, LLC
www.dghsystems.com
Circle 381
