Hot-oil cleaning system
Paratherm Corporation has given its hot-oil system cleaning liquids line a new name: The Sludgebusters. Both the Paratherm SC system cleaner and the Paratherm LC system cleaner remove sludge and carbon build-up in thermal-fluid systems over time. With smaller systems that are shut down regularly, or that need to be cleaned quickly and put back on line, Paratherm SC is a liquid that will do a th...
Both the Paratherm SC system cleaner and the Paratherm LC system cleaner remove sludge and carbon build-up in thermal-fluid systems over time. With smaller systems that are shut down regularly, or that need to be cleaned quickly and put back on line, Paratherm SC is a liquid that will do a thorough job overnight or over a weekend. In larger systems that tend to run 24/7, the Paratherm LC cleans the system while it runs. Replace 10% of an existing fluid charge with the Paratherm LC cleaner liquid, and run it until the next scheduled maintenance stop. Hot-oil systems control temperatures in manufacturing processes in industries such as plastics, foods, chemicals, packaging, converting, pulp and paper, petrochemicals, textiles, and die casting.
Paratherm www.paratherm.com
