The ENA361M and ESA361M series of high-resolution analog output encoders provide 12-bit resolution.
The ENA361M (hollow shaft) and ESA361M (solid shaft) series of high-resolution analog output encoders provide 12-bit resolution. The single-turn absolute encoders are offered with a choice of 4-20mA or 0-10V output and measuring range options of 45, 90, 180 or 360 degrees; they operate over an input power range of 18-30 VDC. Designed to resist high levels of shock (>500g) and vibration (>30g), the products can be used in outdoor applications over wide temperature ranges and fluctuations (-40/+85C). Standard units are IP67 sealed, with an IP69K option available for use in high temperature/high-pressure washdown applications.
Micronor Inc.
www.micronor.com
