The ASIUKH series of high-current terminal blocks is designed for applications that require terminating wire as large as 500 MCM and handling as much as 380 A at 600 V. The terminal blocks are constructed with high-tensile steel metal bodies in order to handle the high clamping pressures that are required for a quality connection.
The ASIUKH series of high-current terminal blocks is designed for applications that require terminating wire as large as 500 MCM and handling as much as 380 A at 600 V. The terminal blocks are constructed with high-tensile steel metal bodies in order to handle the high clamping pressures that are required for a quality connection. With a range of accessories such as jumpers and markers, the terminal block series is suitable for most high-current applications where touch-proof terminations are required.
ASI
www.asi-ez.com
