Hang onto lift truck loads
Quick Claw safety system is easily added to any slip-on attachment by bolting or welding and uses steel cams to lock to the lift truck forks as soon as the load is lifted off the ground.
Quick Claw safety system is easily added to any slip-on attachment by bolting or welding and uses steel cams to lock to the lift truck forks as soon as the load is lifted off the ground. The device minimizes the age-old problem of attachments sliding off the forks and causing accidents.
Lifting Technologies, Inc.
