Grease gun offers efficiency
A low pressure, high volume reservoir filler gun can dispense 14 ounces in less than 60 seconds, provide up to 1,000 psi, will not pump air into a centralized lubrication system and uses a standard electric drill. Not only is the gun convenient, it is affordable. Its lightweight aluminum design makes if durable and easy to handle.
A low pressure, high volume reservoir filler gun can dispense 14 ounces in less than 60 seconds, provide up to 1,000 psi, will not pump air into a centralized lubrication system and uses a standard electric drill. Not only is the gun convenient, it is affordable. Its lightweight aluminum design makes if durable and easy to handle. It has only three moving parts compared to other guns with 10 to 12 moving parts. Alemite Corp. : www.alemite.com
TO VOTE, WRITE 59 ON BALLOT
For more information, write 59 on card
