Gear pumps accurately meter fluids
C-9000 Series gear-type metering pumps match the flow accuracy of reciprocating pumps, even on low viscosity, corrosive, and low lubricating fluids. Repeatability is six times better than required by API for metering pumps.
C-9000 Series gear-type metering pumps match the flow accuracy of reciprocating pumps, even on low viscosity, corrosive, and low lubricating fluids. Repeatability is six times better than required by API for metering pumps. The pump delivers smooth flow with none of the pulsing, check valves, dampeners, and backpressure valves used with other types. Four sizes handle flow rates from 6-1200 cc/min at discharge pressures up to 1000 psi.
Zenith Pumps Div.,
Parker-Hannifin Corp.
www.zenithparker.com
Circle 395
