Gasket material
Permatex gasket makers are available in a variety of formulations to replace conventional gaskets. Noncorrosive, the form-in-place compounds require no mixing and cure at room temperature. More versatile than conventional gaskets, they form to any size and shape and are available in three technologies – elastomeric rubber, silicone rubber and anaerobic – that resist weathering and t...
By Staff July 15, 2007
Permatex gasket makers are available in a variety of formulations to replace conventional gaskets. Noncorrosive, the form-in-place compounds require no mixing and cure at room temperature. More versatile than conventional gaskets, they form to any size and shape and are available in three technologies %%MDASSML%% elastomeric rubber, silicone rubber and anaerobic %%MDASSML%% that resist weathering and thermal cycling. Anaerobic gasket makers are designed to prevent movement in rigid assemblies. The gels cure between close-fitting machined metal surfaces in the absence of air and withstand extreme temperatures.
Devcon
www.devcon.com/85
