Continue to Site
Fire door operator eliminates manual resetting
Fireset 2 fire door operator is drop-tested in a matter of seconds by simply turning the key to the "test" position, allowing the door/shutter to drop mechanically and reset with the push of a button.
By Staff July 1, 1999
Fireset 2 fire door operator is drop-tested in a matter of seconds by simply turning the key to the “test” position, allowing the door/shutter to drop mechanically and reset with the push of a button. This method eliminates the hassle and expense associated with manual resetting. The operator requires no clearance above or below the bracket plate and fitting within the bracket plate dimension. The unit handles fire doors up to 100 sq ft and shutter doors up to 120 sq ft.
Clopay Building Products Co., Inc.
www.clopaydoor.com
Circle 385
