Filter supplies welders with clean air
Fresh-air II SA 9000 respiratory system is appropriate for many welding applications that generate high levels of particle fumes and gases. User-adjustable, belt-mounted airflow valves supply from 6-15 cfm of filtered air. Supply hoses up to 100-ft.
Fresh-air II SA 9000 respiratory system is appropriate for many welding applications that generate high levels of particle fumes and gases. User-adjustable, belt-mounted airflow valves supply from 6-15 cfm of filtered air. Supply hoses up to 100-ft. long connect to a fresh air purification and regulation panel that filters standard shop compressed air so it complies with OSHA, CSA, and ISO standards. The system includes an auto-darkening lens, welding helmet with an airduct assembly, face seal, headcover, and breathing tube.
Hornell Speedglas, Inc.
www.speedglas.com
Circle 374
