Epoxy mastic coatings
A 4-p brochure introduces two high build, self-priming, high-solids epoxy mastic coatings. The literature lists application by brush, roller, or spray, with typical dry film thicknesses of 4 mils on metal and 10 mils on masonry block walls.
A 4-p brochure introduces two high build, self-priming, high-solids epoxy mastic coatings. The literature lists application by brush, roller, or spray, with typical dry film thicknesses of 4 mils on metal and 10 mils on masonry block walls. Curing temperature can be as low as 35 F.
Benjamin Moore & Co.
www.benjaminmoore.com
