Direct drive panel fan
The direct drive APW Panel Fans are designed to provide aerodynamically efficient performance with little or no maintenance and an adjustable pitch impeller for precise performance matching.
The direct drive APW offers aerodynamically efficient performance within a heavy duty welded steel panel and motor base. The APW Panel Fans are designed to provide superior performance and require little or no maintenance. The panel fans are available in diameters from 14-in through 60- in and have capacities ranging to 60,000 cfm. The APW fans also have a factory set, adjustable pitch impeller for precise performance matching. The airfoil axial impeller is constructed of spark-resistant die cast aluminum. Additional features include: factory-set adjustable pitch blades, a deep-drawn steel venture with baked polyester paint, a TEFC industrial duty motor, and no belts or pulleys.
CFM
www.continentalfan.com
