Diode, disconnect, LED terminal blocks
Disconnect, diode and LED terminal blocks are being added to the TOPJOBS terminal block line.
the TOPJOBS terminal block line. The specialty feed-through blocks accommodate
conductors AWG 22-12, and are available in 2-, 3- or 4-pole variants with
single-, double- or triple-deck configurations. Each DIN-rail mount block uses
the standard TOPJOBS profile for seamless integration. Upcoming fuse terminal
blocks variants will offer additional flexibility within the same compact
footprint.
The blocks feature a staggered jumpering system for
convenient potential commoning and traditional push-in jumpers. TOPJOBS
specialty blocks also provide marking options including center and side marking
locations, as well as marker tab and continuous marking strip adapters.
Disconnect terminal blocks feature a test plug conveniently located on the side
of each knife disconnect.
TOPJOBS specialty blocks employ push-in terminations for
ferruled or solid conductors. Termination of stranded conductors is also
simple, insert a screwdriver into block’s port to open clamping unit, push-in
the conductor and remove screwdriver. CAGE CLAMPS Spring Pressure Connection Technology
ensures all terminations are vibration-proof, maintenance-free and immune to
temperature cycling.
WAGO Corp.
www.wago.us
