Cut-off wheels
Cut-off wheels feature a reinforced resinoid bonding system of aluminum oxide abrasives and a thin profile for rapid stock removal and cool cutting.
ALPHA-GREEN cut-off wheels feature a reinforced resinoid bonding system of aluminum oxide abrasives and a thin profile for rapid stock removal and cool cutting. They fit straight and right-angle grinders, produce a small exit bur, and are designed to save time and labor. Available in Type 1 straight-sided and Type 27 depressed-center styles, the cut-off wheels come in 3-, 4-, 41/2-, 5-, 6- and 7-inch diameters, in a 60-grit version that is 0.040-inch thick and a 46-grit 0.045-inch thick. Applications include cutting stainless-steel rod, pipe, tubing and sheet.
Rex-Cut Products Inc.
www.rexcut.com
Plant Engineering
Plant Engineering Staff
