SmartCET corrosion monitoring transmitter provides real-time, localized corrosion indication rate, Stern-Geary constant (B value) and corrosion mechanism indication. The probe is available in a three-electrode configuration with the selection of different probe types and electrode materials. Corrosion rate or pitting factor is available online or as a standard two-wire 4–20 mA HART proces...
SmartCET corrosion monitoring transmitter provides real-time, localized corrosion indication rate, Stern-Geary constant (B value) and corrosion mechanism indication. The probe is available in a three-electrode configuration with the selection of different probe types and electrode materials. Corrosion rate or pitting factor is available online or as a standard two-wire 4—20 mA HART process variable. The transmitter can withstand up to 1,500 PSI process pressure.
Honeywell Process Solutions; IM&C Group : www.honeywell.com/ps
