Clamp-on meter for live circuits
TRMS Model 565 clamp-on meter allows users to locate insulation breakdown on live circuits. The meter is designed to measure low ac current levels, which are typically leakage currents found in ground conductors. The meter also can be used as a standard clamp-on meter to measure up to 100-A RMS as well as ac and dc voltage, resistance and continuity.
By Staff November 1, 2005
TRMS Model 565 clamp-on meter allows users to locate insulation breakdown on live circuits. The meter is designed to measure low ac current levels, which are typically leakage currents found in ground conductors. The meter also can be used as a standard clamp-on meter to measure up to 100-A RMS as well as ac and dc voltage, resistance and continuity. AEMC Instruments : www.aemc.com
TO VOTE, WRITE 37 ON BALLOT
For more information, write 37 on card
