ORSCO 150 Series chain lubricators use a metered spray system. A spray nozzle mixes lubricant with air and applies it where needed on the chain, which results in maximum lubrication and protection with minimum lubricant volume.
ORSCO 150 Series chain lubricators use a metered spray system. A spray nozzle mixes lubricant with air and applies it where needed on the chain, which results in maximum lubrication and protection with minimum lubricant volume. This targeted, nonmisting application reduces lubricant consumption up to 90%.
Lincoln Industrial
Circle 388
