Bearing is adapter mounted
Series 300 adapter-mounted, heavy-duty ball bearing is used in air-handling applications. The units are designed for high capacity and speeds with minimum vibration.
Series 300 adapter-mounted, heavy-duty ball bearing is used in air-handling applications. The units are designed for high capacity and speeds with minimum vibration. Adapter mounting provides maximum holding power on commercial shafting and automatically centers the shaft to extend bearing life.
Rexnord Corp.
