Ball-bearing housing
The pillow-block housing unit is available with either a set-screw or eccentric collar locking system. Designed to be more durable than previous models in both upright and upside-down mounting positions, the housing has flat feet to provide strength, eliminate stress points in recessed corners and prevent accumulation of ambient material under the feet.
By Plant Engineering Staff November 15, 2007
The pillow-block housing unit is available with either a set-screw or eccentric collar locking system. Designed to be more durable than previous models in both upright and upside-down mounting positions, the housing has flat feet to provide strength, eliminate stress points in recessed corners and prevent accumulation of ambient material under the feet. The unit is powder-coated in a black epoxy finish for corrosion protection and includes easy-access mounting bolts.
The Timken Co. : www.timken.com
