Air-operated pumps boost hydraulic pressure
PA9 Series air hydraulic pumps combine easy-to-use features with reliability and durability. They operate in any position from fully vertical to horizontal, and run on 40-120 psi shop air at 20 cfm to produce a maximum pressure output of 10,000 psi.
PA9 Series air hydraulic pumps combine easy-to-use features with reliability and durability. They operate in any position from fully vertical to horizontal, and run on 40-120 psi shop air at 20 cfm to produce a maximum pressure output of 10,000 psi. Features include an extra-large fill port, integral safety relief valve, and sealed reservoir to eliminate leaks and contamination. The hydraulic pressure port swivels 360 deg to position the hose conveniently.
Power Team
