Acrylic silicone topcoat
Cortec Corporation's VpCI-386 HT Black is a high heat resistant water-based acrylic silicone primer/topcoat that provides protection in harsh, outdoor unsheltered applications.
By Cortec Corporation April 14, 2015
Cortec Corporation's VpCI-386 HT Black is a high heat resistant water-based acrylic silicone primer/topcoat that provides protection in harsh, outdoor unsheltered applications.Cortec Corporation’s VpCI-386 HT Black is a high heat resistant water-based acrylic silicone primer/topcoat that provides protection in harsh, outdoor unsheltered applications. The VpCI-386 HT Black is applied to areas that are cracked and corroded and will protect the equipment from further corrosion. The protective coating significantly delays the reaction of metal ionization and water permeation. VpCI-386 HT Black provides a fast-drying thixotropic coating that is resistant to sagging or running. Thermally stable when dried from -150 F to 500 F, the coating is ultraviolet resistant and gives optimal outdoor performance without cracking or chipping upon prolonged exposure to sunlight. VpCI-386 HT Black is heat resistant, fast drying, and UV resistant. It can be applied via spray, roller, or brush. VpCI-386 HT Black protects carbon steel, cast iron, aluminum,stainless steel, galvanized steel, and copper.
Cortec Corporation
www.cortecvci.com
Want this article on your website? Click here to sign up for a free account in ContentStream® and make that happen.
