The DS80 Intelligent Sensor Series is designed to provide multi-parameter analytical measurement of pH, ORP, DO, conductivity, resistivity, and numerous specific ions.
The DS80 Intelligent Sensor Series is designed to provide multi-parameter analytical measurement of pH, ORP, DO, conductivity, resistivity, and numerous specific ions. The series has replaceable cartridge sensors and a standard modular design that can be customized for a wide range of industrial application-specific measurements in the most rugged environments. The digital Model DS80 Sensors store and identify calibration information and communicate via MODBUS RTU with the ability to connect directly to a programmable logic controller (PLC) or a computer. For use with specialized OEM equipment devices or large, complex distributed control systems (DCS), these sensors feature rugged Radel (PES) or PEEK construction with pH bulb protection. The sensors continuously measure ammonium, bromide, cadmium, calcium, chloride, cyanide, cupric, fluoride, lead, nitrate, nitrite, potassium, sodium, sulfide and sulfur. The DS80 Sensors are available in two universal package designs: insertion/submersion or valve retractable with flared-end to prevent blowout.
Electro-Chemical Devices (ECD)
