Air handler system
The 2012 AHR Expo took place Jan. 23-25, 2012 in Chicago. Among the new products introduced at the show were:
The Daikin McQuay Vision Plus air handler system is for applications requiring high static pressure, low leak construction that are typically encountered when advanced filtration and energy recovery are required.
The Vision Plus option provides the ability to attain a maximum of Class 6 leakage at up to +/-8 in. of internal static pressure per ASHRAE’s 111 Standard, which is well under the industry’s high performance leakage standard of one percent. This new option further expands the flexibility of the Vision line and provides building owners with an outstanding solution for applications requiring increased filtration such as in healthcare facilities, clean rooms or labs. Vision Plus, along with Vision’s extensive energy saving options, modular design flexibility, and easy cost saving installation, make the Vision Plus air handler an out-of-box solution for demanding applications.
“From the start, we strived to provide building owners with the ultimate solution in high static pressure, low leak applications,” said Skip Ernst, marketing manager at McQuay. “And, the Vision Plus air handler does just that – its unique variable dimensioning of up to 2-inch increments, modular design, and best in class fan performance provides an economical and energy efficient solution.”
The Daikin McQuay Vision Plus is one of three industry-leading technologies unveiled by the company this fall. Other new technologies include the Daikin McQuay Rebel commercial rooftop unit, which will be the industry’s most efficient unit available, challenging the status quo for energy efficiency with unbeatable part-load efficiencies that are 60% to 70% better than the ASHRAE 90.1 minimum standard. The Daikin McQuay SmartSource water source heat pump with the industry’s first variable-speed inverter is another technology, which boasts energy efficiency ratings unreachable by competing technologies. For more information about Vision Plus and the Vision Air Handler line, and to download the new Vision Air Handler smartphone app, click here.
