The adjustable load lifter is available in 1- and 2-ton capacities. The lifting bail adjusts to the correct center of gravity for balanced handling of different loads, and the throat opening adjusts for different load heights. The unit is also equipped with an auto-return bail to hang level when empty.
The adjustable load lifter is available in 1- and 2-ton capacities. The lifting bail adjusts to the correct center of gravity for balanced handling of different loads, and the throat opening adjusts for different load heights. The unit is also equipped with an auto-return bail to hang level when empty. The tri-adjustable model also includes an adjustable fork spread.
The Caldwell Group Inc.
www.caldwellinc.com
