The A4t line of stainless steel control valves are designed for precise modulation of pressure, temperature, and liquid level in various refrigeration applications.
The A4t line of stainless steel control valves are designed for precise modulation of pressure, temperature, and liquid level in various refrigeration applications including cold storage warehouses, food production plants, and liquid chillers. Constructed of lightweight stainless steel for optimal corrosion resistance, the A4t line is designed to withstand the high pressure and harsh conditions in today’s refrigerated plants. A range of sizes ¾" to 1¼" are available for weld in-line, flanged, or ODS copper connections, and all models have been approved for compatibility with all standard refrigerants (including NH3, CO2, and fluorinated gases).
Hantemp Controls
