Lithium EP grease for lubrication
The CorrLube VpCI Lithium EP grease offers longer lubrication with corrosion protection on electrical connections.
The CorrLube VpCI Lithium EP grease offers longer lubrication with corrosion protection on electrical connections. It is a lithium complex grease formulated with premium quality, severely hydro treated base stock. It provides resistance to oxidation and has high temperature stability; it is suitable for both operating and lay-up conditions. This lubricant’s formula is designed with corrosion inhibiting properties against salt water, brine, H2S, HCl, and other corrosive agents. The CorrLube features Vapor phase Corrosion Inhibitors (VpCI) for areas not in direct contact with the grease. Specifc applications include: metal to metal, lubricating sleeves, ball and roller bearings, fans, bushings, pulley bearings, slidiing high-friction areas, and generator end bearings.
Cortec
