Clean-in-place pump eliminates seals
C-Series eccentric disk pumps do not have mechanical seals, packings, or magnets, which eliminates leakage and reduces maintenance.
C-Series eccentric disk pumps do not have mechanical seals, packings, or magnets, which eliminates leakage and reduces maintenance. The pump is direct-coupled to the gear reduction unit or motor, which improves volumetric accuracy and permits precise metering and mixing. Units can be flushed and cleaned-in-place without disassembly.
Blackmer Pump Co.
www.blackmer.com
Circle 378
