Boost shop air pressure without a compressor
Model 5A-DA-2 boosts shop air to two times input up to 300 psi, while Model 5A-DS-5 boosts shop air to five times input up to 1250 psi. The air amplifier systems consist of a high-pressure receiver, controls, relief valve, gauges, and regulator.
Model 5A-DA-2 boosts shop air to two times input up to 300 psi, while Model 5A-DS-5 boosts shop air to five times input up to 1250 psi. The air amplifier systems consist of a high-pressure receiver, controls, relief valve, gauges, and regulator. At 150-psi outlet pressure with 90-psi shop air, each system can deliver up to 45 scfm.
Hydraulics Intl., Inc.
Circle 376
