Non-contact voltage tester
VoltAware combines a range of safety features, including a CAT IV 1,000-V rating and continuous battery self-testing, with an ergonomic, over-molded cushioned grip. The tester alerts electricians of an energized circuit at outlets, switches and electrical panels without requiring contact with a bare conductor.
VoltAware combines a range of safety features, including a CAT IV 1,000-V rating and continuous battery self-testing, with an ergonomic, over-molded cushioned grip. The tester alerts electricians of an energized circuit at outlets, switches and electrical panels without requiring contact with a bare conductor. If voltage from 50 to 1,000 Vac is detected, it instantly emits a loud beep and its high-intensity LED light switches from green to flashing bright red. In sound-sensitive environments, the audible signal can be turned off without jeopardizing operator safety.
Ideal Industries, Inc.
