8-channel data logger
Microlink 840 data logger
The Microlink 840 is an 8-channel data logger that can also monitor alarm thresholds and output digital control signals. The Microlink 840 is suited for monitoring digital sensors like flow meters; logging data from gas, electric, and water meters; monitoring machines to record percentage on/off times; counting items produced; counting switch closures; and monitoring analogue transducers including pressure, temperature, force, voltage, and current. Windmill software makes it easy for users to configure the Microlink 840 and regularly download its data. Data can be saved as text, xml, or EnergyLens files and to a MySQL database on the Internet or Ethernet network.
Microlink Engineering Solutions
