Ultra-compact servo drives
These servo drives are easy to install and set up, have multiple configurations, copy-function keypad and have a small footprint.
The R7D-B series servo drive reduces control panel space requirements, leaving room for other controls on the same rail. Simple auto-tuning eliminates the need for complicated adjustments and shortens start-up time. Adaptive vibration suppression reduces the amount of vibration as work travels between positions, shortening positioning time and improving accuracy for higher productivity. The torque limiting function in the servo drive allows users to set two torque limits and switch between them to handle applications such as part insertion and pressing for extrusion and embossing. Set multiple servo drives with the same parameters to reduce start-up time by using the copy function built into the hand-held keypad and the configuration software.
Omron Electronics LLC
www.omron247.com
Plant Engineering Staff
