GN 132.5 stainless steel two-way connector clamps are designed to resist moisture build-up in hygienic applications.
The GN 132.5 stainless steel two-way connector clamps are designed to resist moisture build-up for hygienic applications. These clamps have clamping bores machined and are designed for GN 990 construction tubings of DIN 2391, DIN 2395, and DIN 2462 tubes. Clamps and hardware are all made of A2 stainless steel. Type A features without sealing, while Type B features sealing with plastic washers (Polyacetal POM) and an edge ring of Silicon, 40-60 Shore A. The shape of the clamping screws/nuts prevents the formation of moisture build-up. The Type B version seals the mounting hardware bore holes and threads.
J.W. Winco
