Working under pressure
The PC700 offers precision pressure calibration in any environment. Test pressure is generated by the integrated hydraulic pump and read on a four-digit LCD display. A special thin film strain gauge transducer has built-in temperature compensation.
The PC700 offers precision pressure calibration in any environment. Test pressure is generated by the integrated hydraulic pump and read on a four-digit LCD display. A special thin film strain gauge transducer has built-in temperature compensation. Unlike other pressure calibrators, accuracy is maintained when decreasing pressure, which makes it ideal for verifying hysteresis. Units are calibrated in a positive and negative direction.
TTI, Inc.
www.ttiglobal.com
Circle 251
