Voltage/continuity tester
The Vol-Con Elite is a voltage/continuity tester that is designed with low impedance, a vibration mode, advanced safety capabilities, and higher test accuracy.
The Vol-Con Elite is a voltage/continuity tester that is designed with low impedance, a vibration mode, advanced safety capabilities, and higher test accuracy. Courtesy of: IDEAL ElectricThe Vol-Con Elite is a professional-grade voltage/continuity tester that is designed with low impedance and ruggedness, a vibration mode, advanced safety capabilities, and higher test accuracy afforded by digital circuitry. The Vol-Con Elite does not heat up over extended periods of use, and the digital circuitry eliminates the possibility of creating a spike in the line.The Vol-Con Elite will identify voltage up to 600VAC/220VDC, or as low as 24VAC/6VDC, and it incorporates a non-contact voltage sensor in its tip for identifying AC voltage from 40-600VAC. Also, the tester's low impedance eliminates ghost voltage readings that often occur with other digital testers. The testers has bright LED illumination, cushion grip, and replaceable silicone leads that can withstand abrasions and a wide range of temperatures.
IDEAL Electrical
