Vacuum lifter
The VPE-1 is a below-the-hook, self-contained vacuum lifter with an electric power station for handling heavy porous blocks and construction.
By Plant Engineering Staff January 16, 2009
The VPE-1 is a below-the-hook, self-contained vacuum lifter with an electric power station for handling heavy porous blocks and construction. Designed for handling materials weighing up to 4,000 pounds, it features an oversize vacuum pump with a foam sealed-ring suction pad. It’s equipped with a remote pendant and ergonomic handle and is constructed with an all-welded steel frame. Standard safety features include a VacGuard control system with a vacuum reservoir and audible and visual leakage warning alarms.
Anver Corp.
www.anver.com
