Vacuum cups
Vacuum cups are designed for handling round, oval and other hard-to-grip shapes with either smooth or textured surfaces.
Vacuum cups are designed for handling round, oval and other hard-to-grip shapes with either smooth or textured surfaces. Replacement vacuum cups are available to fit any type of vacuum equipment, including lifters, manipulators, pick-and-place systems, packaging, label applicators and robotic end-of-arm tooling. An online catalog allows users to select available cups to match their needs and couple them with accessories such as level compensators, swivel joints, vacuum valves, fittings and adaptors.
Vi-Cas
