Utility-scale solar inverter
Eaton’s Power Xpert Solar 1500 kW inverter for utility-scale solar applications is designed to convert dc power into clean ac and to improve plant levelized cost of energy.
Eaton’s Power Xpert Solar 1500 kW inverter for utility-scale solar applications is designed to convert dc power into clean ac and to improve plant levelized cost of energy. It has been engineered to reduce installation costs, boost reliability, and improve plant uptime by using a skid-less inverter station. The inverter is designed to use a medium-voltage pad-mount transformer, which is connected to the inverter via a direct-coupled throat connection, reducing cable requirements, pad size, and commissioning time. It is outdoor-rated and features a wide maximum power point tracking voltage range.
Eaton
www.eaton.com
