USB DAQ module
The USB-1210 delivers-100 dB THD and 14.3-Bit ENOB preventing data loss from slow CPU response under heavy system loading.
The 4-CH USB DAQ with simultaneous sampling reaching 2 MS/s supporting USB bus power, the USB-1210 delivers performance with USB connectivity. The USB-1210 delivers-100 dB THD and 14.3-Bit ENOB preventing data loss from slow CPU response under heavy system loading. The USB-1210 supports external digital/analog trigger source and flexible trigger modes. In addition, 500 VDC isolation protects the connected computer from hazardous voltage caused by improper signal connection and anti-noise capability effectively prevents improper ground loop interference. The USB-1210 further provides lockable USB for robust connection and a multi-functional stand that fully supports desktop, rail, or wall mounting. The USB-1210 supports Windows 8 and Windows 7 operating systems.
ADLINK Technology Inc.
