Ultra-compact impact tools for technicians
The 35MAX and 15QMAX Ultra-Compact ImpactoolsTM that technicians and operators can use to quickly loosen or tighten a variety of fasteners in confined spaces.
The 35MAX and 15QMAX Ultra-Compact Impactools that technicians and operators can use to quickly loosen or tighten a variety of fasteners in applications such as vehicle repair and maintenance, industrial machine maintenance, manufacturing equipment repair, machinery installation, and equipment disassembly.
The 35MAX and 15QMAX pneumatic impact tools feature high power-to-weight ratios, an easy-to-operate regulator dial with three power settings, and push button forward and reverse capabilities. Each tool has three power settings, as well as full max reverse torque at all levels, so that technicians can insert and loosen fasteners on a variety of equipment and vehicles.
Ingersoll Rand
