Turbine flowmeter has pulsed output
The reed switch output on the WPR turbine flowmeter provides a scaled pulse output that can be used to control a metering pump, or serve as an input to a PLC. The pulse rate can be factory preset as high as one pulse/gal.
The reed switch output on the WPR turbine flowmeter provides a scaled pulse output that can be used to control a metering pump, or serve as an input to a PLC. The pulse rate can be factory preset as high as one pulse/gal. The reed switch provides billable accuracy, reliability, linearity, and ease of maintenance.
SeaMetrics, Inc.
www.seametrics.com
Circle 371
