Touchscreen interfaces
ATLAS industrial-grade LCD color monitors are available in 15-, 17-, and 19-inch sizes. Housed in a heavy-duty steel chassis and powder-coated machined aluminum bezels, all models are equipped with 100-240 Vac input power supplies and NEMA 4/4X/12 panel-mountable front bezel, analog video connections, and “T” models add USB and RS232 connectivity for the five-wire analog resistive t...
By Staff August 15, 2007
ATLAS industrial-grade LCD color monitors are available in 15-, 17-, and 19-inch sizes. Housed in a heavy-duty steel chassis and powder-coated machined aluminum bezels, all models are equipped with 100-240 Vac input power supplies and NEMA 4/4X/12 panel-mountable front bezel, analog video connections, and “T” models add USB and RS232 connectivity for the five-wire analog resistive touchscreen.
AutomationDirect
www.automationdirect.com
