Touch monitor series for industrial applications
Advantech's IDS31 industrial touch monitor series with flexible mechanical design ranges is ideal for industrial applications where display differentiation is a critical factor.
08/12/2016
Advantech's IDS31 industrial touch monitor series with flexible mechanical design ranges from 7- to 32-in. in both 4:3 and 16:9 sizes and is ideal for industrial applications where display differentiation is a critical factor. Courtesy: AdvantechAdvantech's IDS31 industrial touch monitor series with flexible mechanical design ranges from 7- to 32-in. in both 4:3 and 16:9 sizes and the open frame chassis system is designed for rear mounting to existing panels or new designs. The IDS31 series is equipped with a mechanical design that allows for both touch and non-touch versions as standard, which can be adapted to alternate touch technologies such as surface capacitive or surface acoustic wave for low minimum order quantities. The IDS31 series is ideal for industrial applications where display differentiation is a critical factor. The IDS31 series design has an optional black powder coated cover to enable the user to specify a closed frame construction allowing surface, pole, arm, or other standard VESA mounting systems. The IDS31 series is fitted with its own video interface card, DVI/VGA inputs, optional USB for touch screen interfaces.
Advantech
www.advantech.com
March 2018
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
