Ti5X Series infrared
The Ti50 and Ti55 are designed for advanced technicians and professional thermographers working in demanding environments or applications. The Ti5X cameras feature a 25-micron, 320 x 240 uncooled vanadium oxide microbolometer detector, an on-camera Windows CE interface for ease of use and optional, wide-angle and telephoto interchangeable lenses.
The Ti50 and Ti55 are designed for advanced technicians and professional thermographers working in demanding environments or applications. The Ti5X cameras feature a 25-micron, 320 x 240 uncooled vanadium oxide microbolometer detector, an on-camera Windows CE interface for ease of use and optional, wide-angle and telephoto interchangeable lenses. The cameras also feature a temperature measurement range up to 600 C for higher temperature applications and an image capture rate of 60 Hz, offering real-time target temperature displayed live on the camera’s screen. When the AutoCapture feature is pre-programmed, the camera will capture images at preset, timed intervals or when target temperatures are reached.
Fluke Corp.
