Stream switching system
The Gen II R-max Stream Switching System is a multi-functional system designed to control gases and liquids in analytical systems
April 19, 2013
The Gen II R-max Stream Switching System is a multi-functional system capable of integrating both stream switching and filtering into one compact, modular assembly.  The Gen II system features enhancements to the R-max Stream Switching System and is backwards compatible. Enhancements to the Gen II system include a captured vent that prevents cross-contamination; improved position indicator for quick recognition of valve actuation; easier removal of cartridges for maintenance; and an atmospheric reference vent module. The Gen II R-max is designed to control gases and liquids in analytical systems ranging from vacuum to 500 psig.
Parker Hannifin Corporation
www.parker.com
