Status indicator
Display normal or open fuses and report connection integrity with the Model BFA Fuse Status Indicator. With a nominal 3-phase line voltage applied, the indicator flashes a normal LED green light that fives positive indication of a good fuse and integrity of the wire connection to each side of the fuse. The indicator will flash a red fault LED when a fuse is unconnected or open, or if there is a lost connection. Applicable on UL Fuses Class H, J, K,R and RK, the indicator is viewable at a distance and has a universal input of 208-600 VAC.
Dwyer Instruments, Inc.
