Split bearings
A 6-p brochure explains split cylindrical roller bearings with all the inherent features of cylindrical roller bearings, plus the added advantage of being precision machined into halves. This arrangement allows for most efficient use of space.
A 6-p brochure explains split cylindrical roller bearings with all the inherent features of cylindrical roller bearings, plus the added advantage of being precision machined into halves. This arrangement allows for most efficient use of space. Also detailed are a triple labyrinth plus o-ring seal, ductile iron housing and cartridge, and lubrication gallery in the held outer race.
Craft Bearing Co., Inc.
www.craftbearing.com
Circle 322
