Split bearing protection seal
The patent-pending design of the 33K split bearing protection seal combines two different materials. The monolithic housing is made from a flexible, 95A durometer thermoset polyurethane. The sealing interface components are made from high-performance filled PTFE material. Seals are custom-made to ensure they meet application requirements.
A.W. Chesterton Co. : www.chesterton.com
