Spherical roller bearings
Bearings feature a common sphered raceway in the outer ring and an optimized internal design designed to reduce friction
The spherical roller bearings feature two rows of patented self-guiding rollers with a common sphered raceway in the outer ring and an optimized internal design. These features are designed to reduce friction, minimize heat generation, accommodate shaft misalignments and heavy loads, and contribute to longer bearing life. The CARB toroidal types are self-aligning radial bearings merging the benefits of standard locating/non-locating bearing systems typically found in continuous caster applications. They are designed to accommodate misalignment and supplied as full complement bearings to take advantage of their increased load rating.
SKF
