Soothing solution
Problem: Do you have a problem finding a suitable antiseize compound for high-temperature applications? Solution: Use Milk of Magnesia to solve the problem rather than soothe the stomach. Coat the bolt/nut threads before assembly.
Solution: Use Milk of Magnesia to solve the problem rather than soothe the stomach. Coat the bolt/nut threads before assembly. This approach was used in a natural gas burner assembly and prevented fastener seizure.
Contributor: Dale Wendorff, Plant Engineering Manager, 3M TMD Knoxville Facility, Knoxville, TN
- Events & Awards
- Magazine Archives
- Oil & Gas Engineering
- Supplements
- Salary Survey
- Blogs
- Digital Reports
- Survey Prize Winners
- CFE Edu
